Re: bennet/lenco trim tabs?
Trim tabs will easily last a decade or longer.<br /><br />Get Bennetts. <br /><br />Look, there isn't a thing wrong with Lencos and they have at least one advantage over Bennetts. That is they operate a bit faster.<br /><br />On the other hand you are talking about an awfully corrosive place to have to operate, particularly if you are a salt water guy. Given that does it make sense to install an electrically operated device there? Basically its an electric motor inside a casing with a screw dirve to push out a shaft. So you have seals and electricity.<br /><br />The bennetts have an almost indestructable semirigid hydraulic tube that will last forever. If a seal goes in an acculator they are easily replaced for about $40. The control unit, the pump, can be mounted anywhere on the boat that is convienent, mighty nice when you are wireing the thing.<br /><br />I hate to say this but I love to say this too. Bennett has service far beyond anything you have ever seen from any company you have ever dealt with anywhere in the world ever before. You can play around on the internet anywhere you want and get a reply back from one of the couple of Bennett employees who respond to questions about their products. Now, listen to this, if you have a problem and they see it they will respond, and if they respond in ever single case I know of, and there are hundreds - literly hundreds - no matter what the age of the system, no matter what part may have quit, no matter how the systme or boat may have been abused, Bennett has replaced anything and everything that was needed to make it like a new system for Free. That's right, for free. No age questions asked, no question about first or second or third owner, no questions at all. Just ask around, you'll see. Oh, its Tabman or Tabman-II as a name to look for on the message boards.<br /><br />So you look at that and you know its Bennetts you want.<br /><br />Thom
