ingalp01
- Sep 11, 2010
- 357
Hello all,
I think I want these??? Nauticus ST1610-160 Smart Tabs II Trim Tabs???
I'm new to the forums, but not to boating... I know this is a long post, but I wanted to provide as much info as possible for y'all to chew on... Thanks...
I recently purchased a very well maintained 1982 25ft Chris Craft (Viking) Cabin Cruiser. I had it on the lake over the Labor day weekend, and had issues getting up on plane when fully loaded. (Big Boat, 75 gallons of fuel, 35 gallons fresh water, 7 people & 4 coolers... No wonder, right?)
I had to ask a couple of buddies of mine (260 & 190 lbs. respectively) to go forward to get the boat up on plane. After most of the first day, with fuel burn off, and dumping some of the 35 gallons of water I had in the fresh water tanks, she would plane out pretty well, and achieve a top speed of 23mph. Day two, with less people, less coolers and less fuel and water, she planed out OK, and achieved 27mph.
(Prop is a 15 inch 16 pitch 4 blade aluminum and WOT RPM's are bout 5000)
I have been researching Trim Tabs and am very interested in the Smart Tabs, as I'm on a big fairly calm lake in Georgia, and don't like to fiddle with a lot of Buttons. Tubing, cruising, and anchoring are the main uses of this boat.
Does anyone have any info on the Nauticus ST1610-160 Smart Tabs II Trim Tabs, as I think this might be a decent cure. Oh, there is currently a hydrofoil on this boat as well, but from what I have been reading, I would probably want to take that off to add the tabs???
Thanks for any and all advice...
