Howard Sterndrive
- Nov 5, 2008
- 4,603
I had a Seasense float switch (white plastic). Decided to test it with the garden hose (boat floating at dock) and it was NOT reliable.
I had the switch fully submerged and it was floating all the way up, with 3 inches of water over it....NOPE.... no go
I reached under the water and just ticked the unit with my finger and "click"...the pump starts pumping.
I went and bought a new Seasense switch (the only brand they carry locally), and installed it. This new one is grey plastic- old one was white.
Guess what:
Same deal!!!!
If you lift it with a very slow gradual speed (as it would in a slow leak), it will sit in the full up position but not close its contacts.
If you lift it fast, it closes fine and the pump cycles.
How can they make these boat sinking crap switches?
Is there a quality one on the market?
Guess what:
Same deal!!!!
