Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
82 Wellcraft Scarab Warning buzzer/horn goes off under dash sometimes when driving
  • 82 Wellcraft Scarab Warning buzzer/horn goes off under dash sometimes when driving
    Hey There Everyone,
    I bought an older... 1982... Wellcraft Scarab. Sometimes when I am underway traveling at a normal cruising speed, a loud buzzer/horn sound goes off somewhere up under the instrument panel. I have gotten underneath and tried to find where this noise is comming from... but I don't see any sort of speaker or horn up under the panel. It is very loud when it goes off... and I assume it is some type of warning mechansim. It actually sounds like a loud home smoke detector going off. If I put the boat in neutral for a minute or so the sound will stop. But then after underway for a little bit the sound goes off again. Does anyone know what this might be? The sound is coming from right underneath the instrument panel somewhere.
    Thanx a million for your help!!!
    Re: 82 Wellcraft Scarab Warning buzzer/horn goes off under dash sometimes when drivin
    More than likely it means your engine is overheating and you need to get the water pump serviced ASAP. When underway you are putting a heavier load on the engine and the worn out water pump can't keep up. When you slow down and go to neutral you take all the load off the engine and the water pump can cool it. What does your engine temp gauge read under these varying conditions?
    You really need to check that water pump!!!!!
    "97" Bayliner 135 Mercruiser-Then
    "04" Palm Beach Baydancer 215 150 Yamaha 4 Stroke - Now
    • #3
      is it an outboard? possiable mix alarm for oil
      • #4
        Absolutley right!! Almost guarantee it is an overheat. Your water pump is probably failing. Higher rpm means higher heat. And vice versa. When it cools off buzzer stops.
        Get that thing replasced before your motor cooks itself. Fairly cheap fix versus a new motor. Be quick no more outings.
        Good luck
        May you live long and lucky
        1991 Sea Nymph
        25 Yamaha
        2006 Rinker Captiva 192
        Mercruiser 4.3 Alpha One Gen II
        TU TU TANGO TU
        • #5
          Welcome aboard detroitboy!!
          Can be gear lube indicator too although the boat itself is too old for that. The alarm is a small black disk in most cases. Like a very thick quarter.
          Torque gets you there. Horsepower gets you there in time for dinner.
          • #6
            Thanxs everyone for that info... I should have said that the Engines are Mercruiser 200 outboards. The boat was converted professionally several years ago. Used to have i/o's. Would outboards give the same warning for water pump/overheating issues? I don't think the temperature guages work.
            • #7
              My understanding of the audible buzzer is it can be related to a number of issues. It's there so if something goes wrong (not just overheating) it will sound the alarm and your supposed to shut her down and look for the cause. I wouldn't go about removing it, but as suggested look into the cause of it. It could be overheating, but could also be other issues.
              Boat: 1987 29' Cruisers Inc 297 Elegante. T/270 Crusaders. (SOLD)
              Boat #2: 1984 34' Silverton 34C. T/270 Crusaders. Westerbeke Gen.
              Updating Thread: http://forums.iboats.com/boat-restor...vy-534493.html
              Race Car: 1989 Mustang LX 5.0. 12.5 on slicks, 12.9 on street tires.
              sigpic
              • #8
                The warning buzzer could be an indication of overheat or the VRO is not working properly. Either way get it fixed before you use the boat again or you'll be in for an expensive overhaul.
