scbackpacker
- Aug 26, 2009
- 130
I bought an Attwood screw on fuel water separator for my 4.3 liter. Does the separator also have a filter?
I've had mine for a few years and I just unscrew it now and then , dump the water/crud/whatever into a clear container, re-install it, pump it full with the primer bulb, and good to go! Probably the best preventive maintenance item you can get. I'm in Greenville,S.C., so guess we're neighbors!
The filter should be replaced annually.I've had mine for a few years and I just unscrew it now and then , dump the water/crud/whatever into a clear container, re-install it, pump it full with the primer bulb, and good to go!!
"Keep in mind that some day that filter will probably need changing."
Good point! Are the filters available and/or interchangeable with others??
