Re: SQUARE PONTOONS......HELP!
A little company near Chiefland,Fl.makes square pontoons (fiberglass)for all their boats and they are exactly what you are looking for.I am a retired welder and this winter I am building my square pontoons out of 1/8"high carbon steel,26"x 24".I live on the Gulf coast,Fl and we have shallow water with sand bars,oyster bars and rocks ! The easiest way for you to go is by having someone weld STRAKES on your pontoons.A strake is an aluminum
angle bar,4"x4"or 5"x5"or 6"x6"depending on the diameter of your pontoons,this will not however make you float higher at a standstill but will make the boat plane on the go and may help to keep you off the bottom.
