I have a 1991 Crestliner with Morse Tilt Steering. In the need of a replacement part or the whole unit. Because of the age, Teleflex says I need to replace the whole steering system - Tilt mechanism, helm and cables. I'd hate to replace the whole system when its working well, except for a part in the tilt.
The part needed is a plastic black X piece that sits between 2 U joints inside the tilt unit. The plastic piece has worn on a couple edges and has difficulty catching on the U joints when turning. I attached a couple pictures. I'd be interested in knowing if there is either the part or a replacement tilt or straight steering unit I can use with the older helm. I'd hate to replace the whole system because a little black clump of plastic has a couple worn edges. Would be nice to know the manufactor of the piece of plastic if anyone knows.
