I purchased a used trailer for my 29' Monterey and I wanted to make modifications to the trailer to make loading and unloading easier. Currently the trailer has a Y-Bar mounted to a cross member to support the bow.
I've purchased 2x6's, carpet, brackets and hardware to install two bow bunk boards and remove the Y-Bar. My problem is that there is a scupper/strainer in the hull of the boat in the location where I need to position the new bow bunk boards.
Is it ok for the scupper/stainer to rest on the new boards without damage since the vessel weighs around 7000lbs?
