davids_1718
- May 18, 2010
- 29
Well everyone I have one of these. A very affordable fishing boat I can use to catch me some fish in the deeper parts of the bay by where I live. The question I have is would any one be able to offer me advice on cutting out a box in the front and middle of the boat in order to use it as storage and possible store a little 6 gallon tank. Because as you see if I have my daughter with me just for a little cruise there really isnt much spce to sit comfortably with all the neccessary safety equipment needed. I couldnt afford the other model they had available with the live well and battery compartment so I thought maybe I'll just customize it myself and make it the same as the other model.
Pelican Scorpion model # BCA10P106
Features
Modified "V" double hull
Two vertical rod holders
Drink holders
Oarlock receptacles
Built-in motor mount
Deck draining system
Mooring cleats
Length 10' 3'' - 312 cm
Beam 61'' - 155 cm
Max. capacity 520 lb - 236 kg
Max HP 7 hp
Weight 109 lb - 50 kg
Hull material RAM-X
UPC code 776324500532
Features
Drink holders
Oarlock receptacles
Mooring cleats
Beam 61'' - 155 cm
Max HP 7 hp
Hull material RAM-X
