Re: livewell pump in 02 Hurricane 201 deckboat
Jim -
Just out of curiousity, what pump did you use? The pump in our brand new 2005 226 FF was feeble from the beginning, it lasted for just over a year of saltwater use before it died; I swapped it out for a Shurflo Baitsentry 1100. It mated right up to the existing seacock at the thruhull. We have had awesome results, good flow keeps everything alive (we use the livewell to hold our just caught fish and shellfish) and low amp draw -- I can leave the pump running all night and still get an engine start (albeit weak) out of the battery (I do have dual batteries just in case!). However the pump is starting to make noise and lose flow after 5 seasons of heavy use (still has never clogged!). For $90 I think that is pretty good, does anyone have a livewell pump that has lasted longer?
p.s. I feel your pain on the access issue. Without taking the outboard off, I have to hang upside down over the rail next to the tow pole to reach into the bilge to access either the bilge pump or the livewell pump through one of the two 8" access ports. Its definitely not easy!
