Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Mounting seats in my fibreglass boat
  • Mounting seats in my fibreglass boat
    I just bought an old 16ft fibreglass boat last fall (actually a shell) and now i need to install the seats, but the whole floor is raised and fibreglassed, do i just screw it to the floor or do i have to find the studs and if so do they run widthwise and is there a standerdized pattern, for example, every 1 foot, the floor looks like it would have been done in the factory and not by one of the previous owners.
    Once again thanks to all who take the time to answer my questions it is greatly appreciated
    Re: Mounting seats in my fibreglass boat
    Good luck with that and let me know when someone provides good info. as I will be facing that same situation. Sorry I can't help I don't have the know how.
    • #3
      HAHA, This thing seemed great until I realized I didnt know what I was doing, but ya Ill keep you informed
      • #4
        I replaced the seats in my Canadian boat. Went from the lounge seats to pedestal seats. BUY GOOD pedestals. You should have a minimum of 6 or 8 screws and you will be fine as long as you do not have a rotted floor. You can buy them here at I boats.
        http://www.iboats.com/Boat-Seat-Base...view_id.474045
        The reason I do what I do is in the avatar above.
        • #5
          My seats are back to back double seaters, rectangular in shape the base is aprox. 3ft X 2ft. so basically if I put 5 screws down each side of each seat I should be good?
          • #6
            Hmm, typically those seats are made to pull out and folde flat. If you want to post a picture of the boxes I am sure someone can give you a better idea of how to mount them.
            1988 Maxum 2000SR
            Mercruiser 3.0
            Alpha 1 s/n: 6415065
            • #7
              L brackets from the local hardware store against the bottom of the box. 2 in the front 2 in the back and you should be good. make sure you dont drill through the hull with too long of screws though.
              • #8
                My seat bases for my back to back seats are fiberglassed to the floor. its pretty easy to do and then you can just carpet over the glass. If i ran screws down the sides of my seat bases, I would go thru the hull.
                Samuel Adams. Always A Good Decision.
                1987 5.0 OMC capri 1950CX bowrider, 3 bow 6 ft. Westland bimini
                sigpic
                • #9
                  I'm wondering...would it be a good idea to silicone over top of the screws or mounting hardware in-oder not have water penetrate under the deck? Just wondering?
                  • #10
                    I would use some 3M 5200 on the bolts/lag screws if you screw them into the deck. If you go that way, make sure you use a washer and get a good extrusion all around it.
                    San Diego, CA "The 619"
                    "Nemo" (since Jul 2004): 1978 StarCraft 15' TriStar, 1978-88 "FrankenMotor" Mercury 70
                    Unnamed (since Dec 2016): 2000 Sea Hunt Triton 172 CC, 2012 Mercury OptiMax 125
                    "It's always easier to ask forgiveness than permission" -Colin Powell, et.al.
