Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
deoxidizing
  • deoxidizing
    Just bought a boat that has alot of oxidation on the blue paint, someone told me that soft scrub works well cutting oxidation, cheaper than buying bottles of deoxidizer, what do you all use to clean your boats?
    Thanks
    Jeff
    Re: deoxidizing
    When I purchased my boat I used Maguiars Fiberglass Restoration Kit because it has an oxidation remover, canuba wax, and a polish. Eliminated some scratches, the ugly waterline, and most of the oxidation. Pair it with an orbital buffer and you won't regret it.
    I am curious to see what other iboaters use.
    sigpic
    Ryan
    1965 Thompson Thomboy
    1988 Sea Ray Seville
    • #3
      Re: deoxidizing
      never heard of bottled deoxidizer...got a brand name or link?
      this topic has been discussed every which way if you do a search. there's no easy way or miracle product that lasts. rubbing compound or wet sanding followed by polish. lots of laps around the boat by the time you're done.
      • #4
        Re: deoxidizing
        The best stuff I have used is 3m Restorer & Wax its about 17.00 a bottle and works really well.
        1998 Monterey 180 3.0l (The best $500.00 I ever spent)
        • #5
          Re: deoxidizing
          Get it a Wal-Mart? or any auto parts store i'm guessing.
          • #6
            Re: deoxidizing
            No Walmart doesn't carry it. Here is a good spot http://www.iboats.com/3M-Marine-One-...-view_id.39241 or here http://www.***************/webapp/wcs...44&ci_sku=8337
            • #7
              Re: deoxidizing
              Ok thank you.
              • #8
                Re: deoxidizing
                boats dont have paint.....they have gelcoat........its a totally different material and must be treated as such.
                1. acid wash the boat.....(industrial stregnth toilet bowl cleaner from a proper janitorial shop.....not wallmart)
                2. if oxidisation is very bad.....a dry sanding with 8-900 grit then 1200 finally 1500. be careful when you sand....you are not trying to sand the gellcoat off. dont stay in the same spot ....you just want to take the oxidation out. this is done with a variable palm sander with a foam backed pad. hold the sander flat on the surface allways....never on the edge.
                3. proper buffing compound for gellcoat......farecla 300.
                go over the boat with the compound.....do small areas (2-3 foot sq )with the sponge applicator at around 500-800 rpm on the buffer.
                keep moving the compound around till it has worked in......wash the applicator often.....wash it each time you move to a different area
                4. after its applied, use the buffing mop at about 1500 rpm......wash the mop often.
                5. after its buffed.....use farecla glaze....(this is like a wax)with the buffing mop. apply sparingly and again do small sections.
                this will produce a mirror shine to the gellcoat and the oxidation will not return for years........what you are esentally doing is re surfacing the gellcoat.
                cheers
                oops
                The Hull Extension Thread
                great info on all aspects on boat building with detailed information.
                http://forums.iboats.com/showthread.php?t=234392
                IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
                IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
                November 29 2010 RIP
                • #9
                  Re: deoxidizing
                  Good read! the only thing. i would try scotch bright. before sand paper. people tend to sand into jellcoat.
                  • #10
                    Re: deoxidizing
                    cheers
                    oops
                    What is a "buffing mop"?
                    sigpic
                    1995 Monterey Montura 210 5.7l Merc Alpha 1
                    2003 GMC Yukon 5.3l 3.73 gears
                    My Completed Deck/Stringer Restore
                    http://forums.iboats.com/showthread....74#post2486474
                    • #11
                      Re: deoxidizing
                      comet can be used for the black roller marks...if they dont come out with that.....the farecla will get them......the acid wash wont touch them
                      this is the stuff
                      here i was using the mop to apply the glaze
                      wash the mop and applicator often. it can be dryed in a second by spinning it on the sander
                      this is the acid wash
                      cheers
                      oops
                      • #12
                        Re: deoxidizing
                        your right.....they do......but starting with 800 they will be there a while before it happens....
                        • #13
                          Re: deoxidizing
                          from this......
                          to this
                          i didnt sand this one.....just the acid wash and farecla
                          • #14
                            Re: deoxidizing
                            I use the meguiars system.....3 parts. Works well but you have to keep up on it.
                            i would not use soft scrub myself. I think it is a bit abrasive. Might scratch up the gel.
                            Back to Top
