hawkman222
- Feb 20, 2006
- 45
I've got a 1976 Starcraft with a 1984 Evinrude 90HP VRO. It has a Moeller FT1895 permentant mount fuel tank. I bought the boat last year and have trouble with air in the fuel line after the motor is off for a while. I replaced the fuel bulb and can keep fuel from the bulb to the motor just fine. I seem to be draining back from the bulb to the tank. Also, I can only run the tank down to about 1/3 full before I lose fuel altogether. I think there's a problem with the fuel tank pickup. I wanted to pull the pickup, but can't figure out how to remove it. Help on this would be appreciated. There's a check nut on top that looks to hold it in place, but the square part of the assembly on top that you screw the barb into interfers with removal. Also, is this supposed to be a swivel type fitting? It swivels and looks to be a great place for a leak.
