Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
New replacement for boat capacity plate?
This topic is closed.
  • New replacement for boat capacity plate?
    I have older Sears GameFisher which the capacity plate has became unreadable. Does anybody know how to order a new plate?
    Re: New replacement for boat capacity plate?
    fix it with a paint marker
    Kevin
    Originally posted by Tinnie
    But, where are the reevets?
    1981 Wellcraft V-20 CC Fisherman (FREE BOAT)
    1989 Wellcraft Monte Carlo 28(Build thread here)
    1992 Hotsports Jet'n'Cat Yam 701 WR3 drivetrain "SS George Washington"
    90's Yamaha WRIII and a pair of 95 Kawasaki ZXI-900's
    Fresh clean cheap oil is better then old dirty expensive oil any day
    sigpic
    • #3
      Thanks for the info. but the plate has nothing on it because of sun damage. The plate is just white with no lettering. Any other suggestions?
      • #4
        hmmm well I have a friend with an old gamefisher..... there were lots of them tho.... which model do you have? maybe someone can get you a picture of a correct plate... you could then have it printed on vinyl to stick over your current one
        Kevin
        sigpic
        • #5
          It is a 16' Sears gamefisher tri-hull fiberglass. I believe it was built in 1976.
          • #6
            You can have a decal made if you have the info to put on it.
            Try to find another boat like it to get the info.
            If you can't find the info anywhere, the only place to get a new decal/plate, is from the manufacturer.
            Since Dears didn't make any boats, the key to finding the manufacturer is the Hull ID number located on the transom.
            Post that number here, and we can tell you the manufacturer. If still in business, you can contact them for the info.
            If they are out of business, you are up a creek, (may just have to make it up if you need a plate).
            Medford, WI
            • #7
              well my friend has a 14' so that won't work
              so far I found tha PA will issue a plate but I don't know that that would be valid in california
              aye
              or better yet if you read here you will need to click through several pages but all the info is there for you to correctly fill out your old plate and be legal
              Kevin
              sigpic
              • #8
                Thanks smokeonthewater I was incorrect on the length fo the boat. It is a 14' boat. So maybe your friend's tag would work.
                roscoe,
                The number on the registration is SES70142M78F.
                The number on the transom is MFG70142M78.
                Thanks!
                • #9
                  If this number is correct...MFG70142M78...
                  MFG is the Molded Fiberglass Company out of Ashtabula, OH.
                  • #10
                    Yes, MFG made boats for Sears, and thats what you have.
                    But your registration is "counterfeit."
                    THe registration is for a boat made by
                    SESSA MARINE AMERICA INC 850 NE 3RD ST SUITE 201-202 DANIA BEACH FL
                    Good Luck.
                    Medford, WI
                    • #11
                      MFG hasn't made boats in a long, long time. They never really wanted to make boats in the first place....it just sort of made sense as they were pioneers in production methods with fiberglass. They couldn't sell the process/idea to any established boat manufacturers so they built their own boats. Whether or not you will get support from them at this time is uncertain. MFG as a company still exists and is still doing a lot of business in many different markets. However, they haven't built a boat since the 80s.
                      Your boat is a 1978.
                      RJP
                      2004 Four Winns 180 Freedom, 150 HP Evinrude Direct Injection
                      1974 Winner 280 Cruiser, t-302 225HP V-drives
                      2002 Gheenoe 13', 5HP Nissan 2 stroke
                      1981 Four Winns Marquise 180 Cuddy, Mercruiser 165HP I6 -- PROJECT
                      • #12
                        Good Luck.
                        I believe that sears put their own number on the paperwork.... in this case ses would stand for sears
                        Kevin
                        sigpic
                        • #13
                          Once you find the info on your hull, you can have a plate made at Office Depot. My project boat was missing the capacity plate and I couldn't get it from the manufacturer so I had Office Depot make it for me, cost $13. It's polished brass so it doesn't look exactly like the "USCG" yellow/white plates, but has all the info on it.
                          Heck, I've been boating for 15-20 years and haven't had anyone ask to look at my boats capacity plate. Better safe than sorry though I guess.
                          2001 Crestliner SuperHawk 1800, Mercruiser 140HP
                          2007 Tracker 1436 jon boat, 7.5HP Force
                          • #14
                            Thanks for all the input guys. I think I will try fishrdan idea and have office depot make the plate.
                            I was concered about the plate because I was told that Fish and Game looked for the plate if they happened to stop you.
                            • #15
                              No, the MIC code and hull id number is applied by the hull manufacturer, always.
                              Thats why you have boat finishers/sellers like Northwoods, that will have the MIC (first 3 letters of the hull id) of the company that they bought the hull from. They buy hulls from a half dozen different companies, and each hull has the manufacturers MIC code, but they all sell under the Northwoods brand name.
                              SES is registered to Sessa Marine with the USCG.
                              Medford, WI
