Re: Best product to fill in old screw holes in fiberglass deck and hull.
WARNING TO OTHERS!!!<br /><br />If you are ever going to do a permanent repair in the future, NEVER use a silcone product of ANY kind to patch it first!<br /><br />Reason being that it contaminates the area to be repaired later and it is almost imposable the clean residue of the silicone off! The only way to make sure is to remove some of the surrounding material before making a repair to make sure that the new matierial will adhear properly!!<br /><br />The products mentioned are great, but they will not stick if the area is not completly cleaned of silicone!!<br /><br />Hasbeen
