Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
What can I use to lubricate my boat cover snaps?
  • What can I use to lubricate my boat cover snaps?
    That's one thing that I hate...
    Putting my cover on and taking it off...especially during cold weather...
    Any suggestions I can use to make my cover snaps, snap on and off
    easier?
    thanks
    crowdehouse
    Re: What can I use to lubricate my boat cover snaps?
    I've always used Vaseline ....
    Please no PMs. My mailbox is full anyway......
    • #3
      I second vaseline. That's what I use.
      sigpicMarada 2100 Executive Series, 5 Litre V8 with Mercruiser Alpha 1 outdrive. 2007 K-Z Spree 260 RBH, all = a whole lot of family fun !!!!
      • #4
        I've heard Chap-Stick works good.
        2001 Crestliner SuperHawk 1800, Mercruiser 140HP
        2007 Tracker 1436 jon boat, 7.5HP Force
        • #5
          Almost everyone I know uses vasoline (petroleum jelly) on snaps and zippers. There are silicone greases and sprayon lubricants like vasoline too. Choose what silicone type lube you like but good old petroleum jelly works as good as any and it's super cheap.
          • #6
            Yes, it does. And it's not messy, either.
            • #7
              wax also works. good ole block of parafin from grocery store.
              FLORIDA GATORS
              TEBOW Country
              Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
              That is what these forums are for. Post your questions, in the appropriate Forum.
              • #8
                I've used petroleum jelly (found in Vaseline and various lip balms) and someone recommended Lemon Pledge.
                You don't want to use anything that will foul the canvas.
                Southern, NJ, USA
                Currently Boatless
                Date an I/O, but marry an outboard!
                • #9
                  I use a plain old bar of soap, works great on zippers too. Might as well use the grease gun if your using vaseline.
                  • #10
                    Soap is mostly water, is slightly acidic and sometimes contains salt.
                    Southern, NJ, USA
                    Currently Boatless
                    • #11
                      Second the vote for parafin wax. I use it on the zippers (boat cover, tents, sleeping bags etc etc) and the dome snaps. Doesn't leave a greasy residue and lasts longer than soap.
                      • #12
                        Are you aware of the neat little hand tool made just for snapping covers on?
                        I've have not used one yet myself, no arthritis (knocking on wood)
                        I think they're available right here at the Iboats store.
                        '90 Chaparral 2000SL
                        5.8 Cobra
                        '67 MFG Westfield Regal
                        80hp V-4
                        (No private messages)
                        • #13
                          Chap stick for the snaps and lemon pledge for the ensglass and upolstry.
                          2007 Robalo R240 with twin Yamaha F150's
                          2005 Lagoon Heron 16' with Evinrude E-Tech 50
                          • #14
                            I used to use a standard white candle on my old 230Aft cockpit cover. I'd ring the snap (on the canvas), as well as the perm. mounted pieces. This was what the previous owner had done and what was recommended by the canvas shop that had made the cover (they even supplied the candle).
                            • #15
                              when I wax the boat I take a little dab and apply it to each snap.
                              Thats like wiping your butt before you go. You can do it, but it just don't make any sense.
