Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Winterizing Inboard with No Antifreeze
  • Winterizing Inboard with No Antifreeze
    I've got and old mechanic friend who is going to help me winterize my inboard Crusader tomorrow. He insists that antifreeze is not necessary as long as you get all the water out of the engine and anywhere else. He's never does it and he has lots of toys and is very knowledgeable, but it makes me very nervous. Is he right?
    If I do use antifreeze, is the pink stuff enough to protect it. I live in Grand Rapids, Michigan.
    thanks ahead of time....................romertrain
    Re: Winterizing Inboard with No Antifreeze
    as long as all the waters out of the block, go for it air dont freeze up and crack blocks.
    remember to clean out the drain holes as they can plug with rust, chunks, etc
    and possibly, try a shop vac to pull any extras out. did you read the how to winterize sticky
    rob
    home is where we drop anchor
    • #3
      I haven't used anti-freeze either, as long as you get all the water out. I agree, read the Sticky In the "Mercruiser,Omc,Volvo, & Other I/O & Inboard engines&outdrives" forum. Click on the "Adults Only" This should help you get started.
      sigpic
      1991 Bayliner Capri 2050CX,4.3L V6,Mercarb 2bbl,Alpha 1
      (QUOTE): When our boat is happy, THEN we are Happy
      • #4
        It seems people worry about the little residual water left in the nooks and crannys of the far reaches of the block and therefore the antifreeze, I've never done anything but drain the water and Ohio's gets it's share of the deep freeze.
        Little pockets of water I'm sure do get left behind and freeze but it's not enough to hurt anything, open air corrosion would be my primary concern not freeze-up, but my motor drinks freshwater so corrosion doesn't concern me too much.
        '90 Chaparral 2000SL
        5.8 Cobra
        '67 MFG Westfield Regal
        80hp V-4
        (No private messages)
        • #5
          Ayuh,... He sure is Right,.... Listen to the man,... ya might learn something,....
          He already knows, Air just Don't Freeze.....
