unrealisticdreamer
- Oct 11, 2009
- 2
Any owners of an 18 ft Sea Cat out there? I was trying out a 2005 18 foot Sea Cat with a 115 hp Suzuki the other day. There were two people in the boat - myself (260 pounds) and another fellow (a "normal" weight) - no other appreciable weight. I noticed that when one person moved to the back of the boat while at idle or slow no-wake speed, that water came in through the self-bailing cockpit scupper holes. If I moved to the back, the water would be upwards of an inch deep. Also, the boat is equipped with trim tabs and when I leaned over the back of the boat to look at them (at the dock), it sure looked like the tabs were a long ways underwater. Is this normal for this boat? I'm beginning to wonder if there was a lot of water in the bilge or if some of the foam insulation is wet (is there foam in the back of these boats)? When running at 4500 rpm we were doing about 20-22 mph - seems a little low, also.
