Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
How big of a jon boat?
  • How big of a jon boat?
    How big a Jon do I need to be stable when walking around? I've got a 14' semi-v that is fine while I'm sitting but something like walking up front to pull anchor is quite wobbly. I can stand in place just fine mut moving around is the thing that gets me. My inner ears give me problems at times. I get sea sick easy and car sick in a back seat. I weigh 220. I don't want to swim in a dark, cold, angry river. The rivers I fish are too narrow to have real waves on them. I might venture out on a 5k acre lake a bit when it's calm but the lake is maybe a mile wide and long. Mostly I want to scoot through 2' of water and find a nice hole on the river.
    Thanks.
    Re: How big of a jon boat?
    the widest one you can find. wider is more stable.
    FLORIDA GATORS
    TEBOW Country
    Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
    That is what these forums are for. Post your questions, in the appropriate Forum.
    • #3
      And a flat bottom...
      • #4
        1756 or 1860 neighborhood.
        I'm thinking about an 1860, and I have an 1848 now.
        The 1848 is ok, but still has some tilting when moving around,
        whereas the 1860 is more solid on the level.
        Good luck!
        sigpic
        • #5
          Good luck!
          SOunds like you are talking model numbers. What make boat are you refering to. I am confused...
          • #6
            I've gigged alot of suckers out of a 17 x 42, you have to pay attention to sudden movementsespecially if there are others in the boat), but you can walk around. I have a 16 x 50, and it's WAY more stable. You can pretty much stand and walk around without thinking about it. 48 wide is about the minimum for what you're wanting but a 52 would be really stable. All the boats I've mentioned have been flat bottom, no V.
            • #7
              1756 means 17' long, and 56" wide.
              1860 means 18' long, and 60" wide.
              Those numbers are kind of standard for jon boats.
              sigpic
              • #8
                Thank you guys. I haven't been in any of these boats to compare them. I think my little boat might just suffer from lack of weight in addition to its small size.
                I like to catfish. What's fine in the daylight doesn't always work that good at night.
                • #9
                  Never thought of it that way, thank you for clarifying. I have a Jon Boat, more like a canoe with an outboard motor... so I never hear of them in dimensional measurements...
                  • #10
                    Just to clarify a bit, the width number is generally considered the width at the bottom of the boat. I have a 16x52 F&F boat and I can stand on the corner of the transom with no problem. It is a flat bottom boat. Even with a load of hunting equipment on board and 2 people, you can walk around at will anywhere in the boat with no trouble. I can actually stand on the gunwale anywhere and not worry about getting water over the side. If you use the boat in rough water, the flat bottom will beat you up.
                    DG
                    1997 Wellcraft Excel 19SSX.
                    Merc 4.3LX, Alpha 1 Gen +.
                    21P Stainless Mirage.
                    sigpic
                    Back to Top
