Rockaway-Matt
- Sep 17, 2009
- 3
Hello All -
I just put the boat in the water (better later than not at all).
Now I want to install a bilge pump (better later than not at all), but I can not find access to under the floor.
Now my transom has 2 drain holes - both under the water line. 1 of the drain is above the floor since I can see it when I'm in the boat but the other drain on transom is about 1 inch lower to the right and is under the floor (can not see when i'm in the boat). So can I install a bilge pump on a 1964 MFG NIAGARA? I can not find the access to under the floor space. Do I need a bilge pump??
Help... any insight would be most appreciated.
Thanks for the help.
Rockaway-Matt
Rockaway-Matt
