javelinbassman
- Aug 23, 2009
- 1
I have a 1999 Javelin Renegade 20. The Zercom flasher will power off by itself. I think I have narrowed it down to whenever the power switch is on and either the navigation light or the port side livewell switch is activated or when the timer to activate the livewell is on, the flasher will power off. I have checked the wiring which is still the same from the factory, and there are no signs of frayed, or damaged wires. The connections all look good. I have noticed that the light on the power switch will dim when either the navigation switch or the livewell switch is activated. The only other thing I noticed is the Zercom is wired directly to the power switch, but the power switch does not need to be on in order for the flasher to work, does that make sense? The battery is brand new, and I don't really know where to go from here. Any help as to where to go from here would be appreciated. I have also re-done the connections at the battery.
Thanks
Thanks
