Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
bending tool for alum tubes for bimini tops?
  • bending tool for alum tubes for bimini tops?
    Would this tool work for making nice bends in alum tubing for bimini tops
    http://cgi.ebay.com/BIG-HEAVY-DUTY-A...d=p3286.c0.m14
    1986 searay 268 weekender "lunasea" (current)
    1986 grady white 24 offshore with twin 150 yamaha's(current)
    1979 grady white 201 marlin (sold)
    1991 seapro centra 190
    http://picasaweb.google.com/lime4x4/Lunasea#
    https://picasaweb.google.com/lime4x4...hite201Marlin#
    Re: bending tool for alum tubes for bimini tops?
    I don't see why it wouldn't as long as you make some type of jig to get them all the same bends. I was looking for one to build my own wakeboard tower, that should work for you bimini top
    sigpic
    1991 Bayliner Capri 2050CX,4.3L V6,Mercarb 2bbl,Alpha 1
    (QUOTE): When our boat is happy, THEN we are Happy
    • #3
      for aluminum, maybe a conduit bender? ive never used one, but it seems like it might work.
      Samuel Adams. Always A Good Decision.
      1987 5.0 OMC capri 1950CX bowrider, 3 bow 6 ft. Westland bimini
      sigpic
      • #4
        It says that it will.
        Just a little info that I was told. I have a hydraulic tubing bender that can bend tube from 1/2" all the way up to 2" tube or pipe. When I asked on a buggy building forum about bending aluminum they said that only certain grades of aluminum can be bent, the others would kink or break. I just can't remember which grade it was. I have never attempted to bend aluminum before (lots of steel though)so I don't have any first hand experiences with it. I will try to find out for you. It might save you alot of headache
        • #5
          That will probably work if the tubing isn't too hard and no less than .065 wall thickness.A harder type aluminum can easily be annealed with a torch in the area that will be bent.
          sigpic
          In Loving Memory--Sgt.Chad Allen 1981 - 2007
          Link to LAR Memorial
          http://i704.photobucket.com/albums/w...ARMemorial.jpg
          Support All of our troops until they ALL come home.
          Thankfully and Respectfully>>>>Bart Sr.
          • #6
            I have the question on three fabrication forums, so it's only a matter of time.
            • #7
              What about talking to an electrician with a bender/hickey bar. That would be cheaper than buying one.
              ~~ This boat runs on gas, NOT thanks ~~
              • #8
                Duct tape the end of the tube, pack it with sand and water, then duct tape the other end before bending. You'll prevent breakage, kinks and wrinkles.
                Learned on youtube.
                CHAD
                sigpic
                1979 AMF Crestliner Muskie 550 14'
                1978 Evinrude 70Hp
                2005 Durango Hemi
                • #9
                  If I wasn't laid off and wanted to make my own I would take the materials to work with me and do it on my own time.I have 27 years working with benders and could make all the tubes in about an hour.CNC machines make it very easy.
                  sigpic
                  • #10
                    good morning-
                    if you can swing it go with stainless tube as it is a lot tougher than aluminum
                    and if there is a good blow up while your on the water, you know that stainless wont bend and twist as easilly as aluminum.
                    rob
                    home is where we drop anchor
                    • #11
                      Learned on youtube.
                      CHAD
                      Yes that will also work.
                      All the buggy buildr guys said that you can bend the softer stuff such as 5052, and 3003. If you want to use 6061 you can eithe pack it with sand or heat it up with a torch.
                      Hope this helps
                      Back to Top
