OK i have a boat(clearly) and the slide in part of the rub rail is damaged in several areas. I've found a very good price on some Honduran mahogany that, with a little table saw work, would fit nicely into the slot left by the previous rub rail. Also, as i said, a very good price on the mahogany, its actually cheaper(bearing in mind that i do my own woodwork) than replacing the original taco (manufacturer) part. Now my concern is whether the mahogany will be able to bend, preferably without steaming or anything like that, to the hull, I'm not concerned about the actual corners yet, but the boat is rather wide, i believe about 6'4, on a relatively short length, 14. I would like to not have to slot the back of the insert, but if needed, how deep, how many, how close together, etc. thank you for any input.
