twintrades
- May 7, 2008
- 305
OK i have a mecruser outdrive. My question is can i take the fill screw out and run the pump ? I have to take the boat out in the lake to fill the resivior. ( to shallow at the dock)
Is it ok to drive out. Stop with engine off. And take the screw out and fill the resivior. Then i was going to run the trim all the way up ( trailor mode) and down a few time with the screw out. Will it just spit the fluid out or will it pump right ?
Reason is last time i filled it with the drive not all the way down. And when i took the fill screw out it spat at me. Also how do you bleed the system ??
I think i have to get a new line. But want to make shure that the line i tightend last night wasnt the culprit.
