Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Alarm sounds before cranking motor?!
  • Alarm sounds before cranking motor?!
    I just took the boat out last weekend and ran great. I put the boat in yesterday and when I turn the key right before turning the motor over the alarm sounds. WHat would cause this a short somewhere, because the motor is not overheating and peeing, heck the alarm sounded out of the blue ?? Could it be a battery voltage issue?
    Boatless again for the second time, but the pockets are fat
    Time to search for boat #3.
    Re: Alarm sounds before cranking motor?!
    It always does that. You should hear the alarm sound when you turn the key to the on position if the motor isn't running.
    • #3
      Yes, but it stays on after the motor is on. The motor is not overheating and peeing just fine. It has never made this sound before.
      • #4
        So it sounds before cranking and WHILE RUNNING ?
        My 1970's vintage oil buzzer sounds horrible, turns right off after start-up.
        1977 Starcraft American 18' 165 Mercruiser.
        http://s226.photobucket.com/home/win...obra/allalbums
        • #5
          I had the same continuous alarm on my boat. It turned out to be a faulty tach gauge. The tach gauge had all the warning lights built in. Had to replace the whole gauge. My setup is a 2005 Aloha pontoon with a 115 Johnson 4 stroke. Hope this helps.
          • #6
            On many engines, it is standard to have alarm and lights when the key is turned before starting.
            This lets you know that the alarms are working. At least the oil pressure alarm, which loses its ground when oil pressure gets above 5 PSI.
            Hope you don't have a problem with your boat.
            Farmer's Tan....year round
            • #7
              Well it turned out to be the battery. I read elsewhere that sometimes the voltage of your battery will casue the alarm to sound right away. I replaced with a new battery and problem solved.
