how to convert 15" transom to 20" on Alumacraft T16-XL?
mustelameister
First-time poster, many apologies if this topic has been covered before.
I've just purchased a 1986 Alumacraft T16 XL V-bow, utility fishing boat, and wish to change the transom from 15" to 20" This is not a picture of this particular boat, but another just like it:
I've just begun the process of looking for instructions on how to do this, and stumbled onto this picture:
Very nice.
So . . . how do I do this? Is there a kit out there?
ANY help would certainly be appreciated.
Many thanks,
Mike
clarkbre
Re: how to convert 15" transom to 20" on Alumacraft T16-XL?
It all depends on how you are using the transom. If you're looking to just raise the motor then you could build a simple riser block. If you're looking for more splash protection you can build a full transom all the way across. I think to do it right, I would take off the existing metal cap, take out the original wood, then put new wood in with a 5" rise.
