Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
How to remove and change Bilge pump on 89 Bayliner
  • How to remove and change Bilge pump on 89 Bayliner
    How do we get to the bilge pump to replace it on our 89 Bayliner outboard.
    Thanks
    Re: How to remove and change Bilge pump on 89 Bayliner
    Do not know what model you have but, there should be an access port in front of the motor.
    • #3
      I also wanna know how to go about doing this. On my bayliner capri cuddy which i believe is a 87 or 88. I have an 85 Force outboard motor. There is a little cubby in the back of my boat under where the engine is when raised. My pump makes a sound but doesn't pump out water. Its a real tight squeeze to get under there. I never had to change out the bilge pump, so i was just looking on how to go about doing this and if anyone has done it. Thanks in advance
      • #4
        I change mine one time my boat is a Baylinner cuddy cabin 1989 with a 125hp force, mine pump has a broken tube end, so I just pull it up form the base and come out. I glue the tube and put it back togheter. I know is really small space but it is possible.
