islander12
- Apr 26, 2005
- 20
Ok, so my turn to come up with a dumb question. Forgive me!
I recently acquired the above craft, which has an aerated live well in front of the console. On the dash there is a switch for the aerator.
How do I fill the well? I suspect it should have a pump, however there only appears to be a drain hole. So I am unsure and can't seem to locate a pump, although at the aft section where the bilge pump is located there appears to be a tube that feeds toward the bow and splits to a hose adapter on the transom. Could this be a feed for the wash down and the well & if so why can't I get water through it?
Any experience advice appreciated, as I have never used/operated a live well with past boats.
