Re: Need new side mount control
If you take that back plastic cover off of the outdrive, held on by three bolts, you should be able to see the cable where it shifts the drive. have someone get in the boat and move the controller back and forth, and watch the other end, if it is moving but really sticky or tight then you need new cables, you can also look at the cable at the Carb and see if it is moving in a fluid motion when you move the controller as well. Either way you should be able to determine pretty quick whether it is the cables or the controller. Be careful, if the cables are too tight you can actually break the controller trying to move it back and forth. If the cables do not move when you move the controller I would replace the controller, if you do replace the controller do the cables at the same time so you know that everything is working properly.
