thomasalva
- Apr 30, 2009
- 31
I have a 1989 Cobalt 21BR which is in need of a new pair of engine hatch/rear seat lift arms/shocks/props/struts (whatever they're actually called). I've contacted a local dealer, but so far they can't find the specs for them. The brand of mine says Suspa, but the numbers are too faded from the paper tags to make out anything.
They are 36 inches long, and I've found Suspa sources online, but I don't know what the lift rating should be. I've found them in 40, 60, and 100 pounds, but I don't know which one would be best.
This boat has the long continuous rear bench seat/engine hatch. If someone has a similar boat, I would appreciate any part numbers or specs you might be able to find. I have to clamp mine with vice grips to keep the hatch open.
Thanks
Thanks
