I have a Yamaha 40 hp 4 stroke with a Panther 55 tilt/trim unit. I am moving it to a small pontoon boat. The brand new, never been the water pontoon has a Mercruiser Binnacle control with a two way button on it for tilt/trim. The Panther control is a two button three wire switch. Is there any reason I could not use this to control the Panther? I assume I would have to splice/wire in the Panther plug to go to the wires from the Mercruiser control. Thanks for any advice you can give me.
Keith
Keith
