Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
How to safely move 'dry' dock back into water
  • How to safely move 'dry' dock back into water
    Hello
    I recently purchased a lake house with double slip boat dock that is currently 'dry docked', i.e. sitting on land (see attached picture).
    Does anyone have any recommendations on how to move the dock approximately 20' - 30' feet back into the water without damaging the dock? I have tried googling this, but I can't seem to find information on how to do this properly
    Thanks in advance
    Re: How to safely move 'dry' dock back into water
    Ayuh,...
    Jack it up, place some planking down as skids,+ Drag it to the water....
    • #3
      Buy some beer and invite over a bunch of your strongest friends/neighbours.
      • #4
        gil,
        Looks very familiar, are you on lake lanier??? You will have real trouble trying to jack the dock up. Your floats will be water logged (even if on land for years), they are heavy and will fall apart as you lift (even if encapsulated). Friendly advice, call a dock moving company, pay a couple of hundred bucks to have them do the moving. If you are on lanier several companies offer this serivce and they are all hurting for business at the moment. Call one that's nearest you.
        • #5
          lkbum, thanks for the response. As a matter of fact, I am on Lake Lanier! I'm impressed you could tell it was Lanier.
          Actually, I did call one place today and they said it would $300 - $500 (of course this is without coming to look at the dock). It sounded like they would jack it up and drag it out over PVC. I guess I was trying to save a little money and was wondering what they would do differently than I could do?
          Cheers
          • #6
            pray for rain!!!!
            FLORIDA GATORS
            TEBOW Country
            Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
            That is what these forums are for. Post your questions, in the appropriate Forum.
            • #7
              Why was the dock pulled in the first place? Lake Lanier is in GA. right? Does it freeze over in the winter. If so, pulling it out at the end of the season and putting it back in at the beginning of the season would be an annual event. I live in a northern area and that's what happens on my lake. I'm lucky to live on a channel with little water movement so we've always left our pier in. It's worked out fine for the last 4 generations so no need to change now. Anyway, if this indeed an annual event, pay to have the Pro's do it. Watch how they do it and if it looks like something you can do, go for it in the future.
              1974 Century Resorter
              2008 JC Suntoon Triple Tube
              2007 Sea Doo Speedster SCIC
              • #8
                lake lanier is in a drought. the dock is probably at whatever water level the lake was at when the previous owner left.
                couple hundred bucks doesn't sound bad. doesn't look like a fun job unless you know the tricks.
                • #9
                  Yep, it is in Georgia, but definitely does not freeze over. The problem here in GA is that we have been in massive drought and the lake has dropped several feet. The previous owner did not use the dock and therefore never 'chased' or moved the dock to deeper water when the level decreased. Once I get it moved into deeper water, I will make sure that I monitor the level.
                  • #10
                    sounds like a job for manly men and alcohol to me!
                    The reason I do what I do is in the avatar above.
                    • #11
                      YUP
                      • #12
                        Maybe make friends with the neighbors? Some of them should have equipment to help you out.
                        You can jack them up on logs then roll it to the water?
                        sigpic
                        25'.6" Cuddy Cabin
                        • #13
                          Personally I'd pay to have it done.
                          It looks like you have encapsulated flotation. The attachments aren't made for a lot of lateral movement.
                          My guess you would need 4 to 6 pump jack poles, a bunch of 6x6s with greased bunknaps. Lift up the dock, slide the 6x6's underneath and pointed towards the water. Figure out how to push the dock on the 6x6's and into the water. You'd pick up the 6x6's from behind the dock to in front as it moves.
                          2009 Neptoon 25TT Sport Sun Lounger
                          150 Honda
                          Older than dirt and just about as active.
                          Back to Top
