Installing a ski pole
twr7cx
I'm wanting to install a ski pole into my boat. But I've really go no idea how. None of the shops down here where I live seem to stock anything, so the internet so far is my main source.
I've seen the Insanity Wakeboard Pylons/Towers ( http://www.insanitywakeboardpylons.com/insanitypylons/products00.html )which are removable and an easy enough concept, but I have an issue in that the base of the skipole has to rest against something immovable on the boat.
Then there's also permanent mounted poles, which I would prefer, this is a local Australian company - http://www.fluidcore.com.au/pages/highpoles.html . But I can't figure out how I would mount that base in my boat.
Photos of the back of my boat:
Any ideas/thoughts?
mthieme
Re: Installing a ski pole
Go to the iBoats marine store, type in "ski pylon" and you'll get a page full of choices that look like they would work easily with your boat.
twr7cx
Seen.
I don't understand how they mount on though?
These ones, http://www.iboats.com/Swivl_Eze_Run...26382790--**********.486073004--view_id.38614 or http://www.iboats.com/Swivl_Eze_Sta...226382790--**********.486073004--view_id.3954 , would be good as it's the tallest out of the lot. But how does it fit on?
salty87
looks like they just screw into the floor. not ideal but i've ridden behind pylons like that and they still work.
under a load, the rear 2 legs will be doing most of the work. a factory install would include securing the pylon to the stringers but i doubt you want to go there.
pylons or poles that use straps to the bow are similar. the strap takes most of the stress when there's a load. the cable can get old if you have an open bow though.
can't beat a tower.
Splat
Yes but you can't tube behind a tower!
Bill
