Re: Rotary Steering Cable Replacement
you are almost right. there is a pin that is in it's storage place. the pin has to be removed, then inserted in to the release, hole. it is spring loaded to hole the sheathed in place so the cable slides. there also is another style that has 2 bolts on the side of the cable, they have to be removed. then there is the style that the sheath has a nut that threads onto the helm.
then you turn wheel to remove. just opposite to install.
