Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
Drilling fiberglass with hole saw
  • Drilling fiberglass with hole saw
    I need to drill a 1 1/8" hole in the fiberglass of my boat to install a plug receptacle. Can I accomplish this with a standard hole saw without problems? The fiberglass is about 1/4" thick. I've read about starting the hole with the drill in reverse to prevent the gel coat from chipping. Is that my only concern? Will the hole saw cleanly cut through the fiberglass otherwise?
    The instructions for the plug just say 1 1/8" hole saw, but I thought I'd ask before I butcher something.
    Thanks
    '94 Bayliner Capri 1850 4.3LX / Alpha One Gen II
    Get right or get left. <*{{{><
    Re: Drilling fiberglass with hole saw
    Yup..a hole saw is your best bet..if possible attach a piece of duct tape on the hull and mark your hole location on the tape..then drill,use a good quality NEW bit to minimize gelcoat damage.
    Nec aspera terrent
    • #3
      drill a small pilot hole first, then start the hole saw in reverse to score the gel coat, then go to forward and cut it.
      FLORIDA GATORS
      TEBOW Country
      Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
      That is what these forums are for. Post your questions, in the appropriate Forum.
      • #4
        Do you have access to both sides?
        You do not need a parachute to skydive. You only need a parachute to skydive twice.
        I don't belong to an organized political party. I'm a Democrat. (Will Rogers)
        • #5
          Not really. It's the inside edge of the bow. I can just barely reach my hand up there.
          • #6
            Covering the cut area with tape is a good idea to prevent chipping. Use the blue painter's tape for a best result. Duct tape is a little gooey and will stick to the saw blade and make a mess on your hull.
            “We do not inherit the earth from our fathers, we are borrowing it from our children.”
            • #7
              i just drilled 2 holes with a holesaw in my fiberglass boat and had no problems.....i didn't know about the"backwards trick"....and i didn't have any chipping, but i would try it, wouldn't hurt.
              • #8
                In addition to the good advice already given I'd like to add that the backside of the hole will end up a little rough. Can't be avoided unless you can get to the back side and partially cut thru.
                The other thing to know is to use a low speed and high pressure. High speeds and hole saws don't go good together. Use a dust mask, you'd be surprised at how much fiberglass dust it will create.
                • #9
                  I'll add another trick, If you ever have to enlarge a hole you will find it difficult, because there is no place for the pilot bit in the hole saw to drill into. Trying to place the large portion of the hole saw in the correct position, while engaging the drill won't work - you won't be able to keep it in place and will end up with a scarred boat, and a hole in the wrong place.
                  Instead, clamp or firmly wedge a thin piece of wood (1/4" ply or similar) to the area to be drilled. Measure carefully to find the correct center point, and start the pilot bit in the wood. The bit will then keep the hole saw in place, resulting in an even hole, in the location that you want it.
                  Please don't PM me on advice issues - let's keep that in the forums, so that everyone can benefit. Please note that I do not email PDFs, etc. I have a bandwidth limited aircard for internet access. My avatar does not mean I have any offical link to iboats. I just like it!
                  • #10
                    That's a pretty cool trick. It occurred to me, although I haven't tried it (yet) if you used a piece of plexiglass you'd be able to keep track of progress. Also less chance of messing up measuring.
                    Why does a round pizza come in a square box?
                    • #11
                      plexi tend to melt, and gum up hole saw.
                      FLORIDA GATORS
                      TEBOW Country
                      • #12
                        1994 Bayliner Capri 1604 w/94 70 Force (sold)
                        1984 SportCraft 222 OFF w/84 Mercruiser 488 & Alpha 1
                        1979 Sears Gamefisher 13'6" Aluminum w/1959 Johnson 10HP
                        1969 Smokin' Hot Wife
                        • #13
                          I just wanted to report that this install was a success. The hole saw worked beautifully! I didn't bother taping the spot. All I did was run the drill in reverse nice and slow to begin cutting the gelcoat. Worked great and no chips at all!
                          I would like to post some pictures, but I've been way too busy.
                          • #14
                            Thanks for letting us know how it turned out.
                            Glad it worked out for you.
                            sigpic
                            Nothing is so broken that Government can't make it worse.
                            • #15
                              True, dat!
