I was coming home yesterday and about 1/4 mi from the house I noticed the boat was about 6" from the winch. I knew it was the eybolt as at the dock it looked a little like the lower part had pulled about a 1/8" out. Anyways, when I examined the u bolt, the side that was loose looked about 1.5" shorter than the other one. The boat itself looks ok except there are two holes in it now where the eye bolt was. The u-bolt came out 'clean' (ie - it didnt pull the backing plate or washers through any rotting wood. I suspect the bolts on the backside came loose and fell off (weird, right?). Problem now is that I can't access the back side where the backing plate is (I have a 1986 Sea Sprite fiberglass bow rider). How do I gain access to the other side? Do I have to cut through the storage compartment under the front cushions? If so, how big should the hole be?
thanks..
thanks..
