Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
my trim /tilt won't go down , why?
  • my trim /tilt won't go down , why?
    it will go up but it won't go down, i check switch and its fine , and i pull the lock lever off. don't know. evinrude 135 1976. why?
    Re: my trim /tilt won't go down , why?
    My 1992 Johnson would go down but not up. I followed the wires to the relay box, switched the relays and it would go up but not down. A $6 relay from NAPA solved the problem. Of course I siliconized the bottom of the relay to seal against moisture.
    Age and treachery will always overcome youth and enthusiasm
    • #3
      It could be a relay or lack of fluid in the pump. Try them both.
      • #4
        thanks for replying , u 'll were right the relay went bad , its working now,and its also low on fluids...need to get some. thanks again.
