Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
See more
See less
Hull design question
  • #1
    Re: Hull design question
    Examine the hull lines in profile and you will see a subtle hook. Which does help keep the bow down. And perform well with less power. Unfortunately many, many boaters assume hook is always a defect. Not true, it can be beneficial, and is designed into some hulls. Though the designed in version will not look exactly like the popular idea of what hook is thought to be. Different priorities for different brands.
    Kelly
      Of course there are drawbacks, or everybody would have copied this. Kind of the same drawback as if you left your tabs slightly down at all times. Not optimum at high speeds.
      Kelly
