mike64
- Apr 10, 2008
- 1,042
Noticed my eye bolt was loose last time I took the boat out-- went under the bow to tighten and found the 2 bolts went through a piece of backing wood that was like a 2" x 2" about 6" long, shaped into a wedge to fit into the bow "crease". The wood piece wasn't glassed in, just held in place with the eye bolt. Each of the 2 bolts from the eye going through the wood piece had a spring washer/nut/spring washer/nut setup that had apparently been tightened so many times they were sunk halfway through the wood. There was a crack going down the center of the wood piece-- think I was a winching or 2 from ripping the eye completely out.
So I used the old piece of wood as a template and shaped a new piece from PT wood, and used fender washers against the wood so the nuts wouldn't sink in to the wood (so it's fender washer/nut/spring washer/nut now). Used 4200 for waterproofing.
My question is, is this adequate to support the bow eye? Except for using the fender washers, I basically just recreated the old setup, which I don't know if it was original or somebody's bad repair job. It's a 900-1000 lb. 16' boat.
Didn't think to take a pic, but if my long-winded explanation doesn't help, I'll post one tomorrow.
