I have a bass boat, with a built in fuel tank with a flip open deck fill opening. It turns out this is not waterproof when closed. I had to drain the fuel tank last week, due to water and engine not running. Put a fuel/water separator on it, refilled tank, everything was good. Took out yesterday, boat ran fine and then all of a sudden would not run. Again water in the tank, now I know some water does ride up over the transom in rough water or when going from full speed to idle. Any suggestions on how to cure this? I was thinking to put a new deck fill with a water tight cap, but this does not seem possible.
Thanks,
TEx
Thanks,
TEx
