Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
how to shine aluminum rails?
  • how to shine aluminum rails?
    I was cleaning my older pontoon boat and I guess some of the chemicals were to harsh for the aluminum rails around the boat.
    What is a good product to make aluminum shine and look close to new again?
    Thanks in advance
    Re: how to shine aluminum rails?
    I've had good results with WD-40 sprayed on, & wiped down, it preserves too,,, or, Gel Gloss fiberglas, & metal polish from Home Depot, or Lowes, by the way, (Seapower boat wax) is the same exact thing.
    • #3
      Mothers makes a paste that works well, as does 3M. Another great product is this link below. I really prefer it to a paste in many applications. If you do use a paste, start with a small amout in a small area. A little dab will do ya.
      Shine on
      http://www.nevrdull.com/Where.htm
      • #4
        It sounds like the cleaner you used etched the aluminum. This may take some mechanical pollishing. I would think any aluminum wheel pollish would clean it up. That and some elbow grease.
        • #5
          Flitz
          with buffing wheel on drill
          • #6
            http://www.nuvitechemical.com/
            Rick
            "Boating is Life...All the rest is just Details"
            2007 Bentley 200 Cruise
            2007 Merc. 90 4 stroke
            • #7
              Flitz, never dull, WD-40...
              • #8
                Almost forgot, Mothers Power Ball (foam-2 sizes) Works good with paste, like the flitz tip from captain zac.
                • #9
                  Nevrdull and then your fav wax.
                  • #10
                    as long as they are not ribbed wet sanding with fine sand paper works.. use lower grit for bigger scratchs, work up.. buff off with mothers. your rails will look like mirrors, i promise! i ussually finish with 1600 or 2000 grit. then hand buff with mothers.. its time consuming, but very very worth it for intricate detail!
                    • #11
                      Be careful. The rails on mine are anodized. Anything that has abrasive in it will eventually remove that thin layer.
                      Which will allow the underlying aluminum to corrode like you never saw before.
                      And you will have to polish and wax for ever more.
