Re: Lacquer thinner????
Aluminum or glass?
If it is aluminum and you are painting bare metal make sure you use an acid etch primer, car primer won't stick.
If it is just a repaint I have used thinner as a prep solvent, let it dry and tack cloth before you hit it with paint.
Don't now how much you have painted but prep is the key, did my truck last year, oddly enough I hit a guys guide-on at the launch, his trailer was fine but didn't do much for my truck, spent 30 hours on prep and 4 actually painting it.
Good luck.
