I just bought a 240 Sundancer with Bravo III I/O. The throttle control has a power trim switch on the side. My trim guage appears not to be working so that I can't tell the status of the outdrive. The boat has a swim platform so that I can't see the outrive from the stern. The mechanic at the marina said it could be expensive to fix. Is this the same control that tilts the outdrive all the way up for palcing it on a trailer? Can I inadvertently tilt the unit so that the props come out of the water while I am cruising? Do you use this trim to adjust the bow angle while planning? Shouldn't I be tilting it up if approaching shallow water?
Thanks,
RK
Thanks,
RK
