U Bolt Bow Eye
larryo
Was surprised to find the bottom hole of the plate that supports my bow eye was being used to tie off the anchor rode of my windlass . The eye is supported by the top hole of the plate and nut but the bottom has the nut only . On a 89 GW 20 ft W/A . Doesn't seem like the right way to do this . Comments please .
Silvertip
Re: U Bolt Bow Eye
Certainly not a good idea to not have a backing plate under both nuts. Make another plate so both can be used, or else put the original back where it belongs. Then stop at a hardware store and get a piece of flat stock. Drill a hole in it and mount it under one of the nuts. A hole in the other end will provide a spot to tie off the rope.
larryo
Re: U Bolt Bow Eye
Thanks Silvertip , Don't think the dealership owner is going to be happy to hear about this workmanship . Pay top dollar and expect the best from them ,that's what keeps me coming back . I only trailer to my slip and back and a few short runs yearly but I thought I was as safe as possible . Will follow your advice . Larry
