Re: 1st Boat Montgomery Ward 12ft...Please HELP
SORRY FOLKS...THE GUY TOLD ME WRONG
looked at the white plate on the transom board...it is soooo hard to read anything on it...most is scraped off..anyway...found the model number of
1430-12
looked this up...and found the REAL maker...Starcraft 1430-12 11.5ft 80lbs...can cary 300lbs..and max of 5hp...
so here is the deal. i got a seat and swivel mount..and stand...i think this will be the case...seat sitting too high when mounted on the back bench...and the back bench seams really close to the motor...and the handle will probably reach to the seat (just a guess) the motor is a Johnson 7.5hp motor...that is all i know. i have not purchased it yet. it is Grey...i have not seen it either...but i am only paying $100!!!
anyway..so i put the seat partway on...and if you push down on the stand...the bench metal pops from bending in a little...so i am gonna put some wood across both benches to give some stability...i was also thinking i might put some sort of coating on the bottom to make slip resistant so the dog isn't slipping around when ducks are flying in...and i was thinking about making a stencil...and spray painting the outside a camo color...like light brown to look like the sadow grass camo..but not nearly as good of course. the transom board is softer than cake...so i am probably gonna put some wood on the outside of that...both on the iside of the boat and outside...what kinda wood should i use...and any recommendations on how to attach it? i don't wanna make holes...and can't really work with the rivets in the boat. i will then try to rig some wheels on it that will flip up to sit in the boat when on water...and flip down so that i can drag it to the water with ease.
here are some pics of it right now
this is the boat with some tools in it...since i am working on it
this is some pics of possible motors that might be the one i am buying
i think it is probably the 1st one
http://i170.photobucket.com/albums/u267/davidsportfolio/johnson3.jpg?t=1204224709
http://i170.photobucket.com/albums/u267/davidsportfolio/johnson5.jpg?t=1204224735
this is a pic of some random boat like it
see the white plates on the transom board in the 1st pic?
