Does anyone have any experience with either swing up or pull on davit systems? I have a 23' Trophy 2359 with a 8'5" beam and 24" height from swim platform to the to of the transom. The width of the dinghy is 62 inches which means it will stick up quite a ways above the transom if I use the swing up models. It is also 11' long but I can offset the dinghy if I travel to other marinas. It is not a problem at the one I keep the boat at. On the other hand, the pull on systems will keep the dinghy flat on the swim platform but cost three times as much.
My questions are which do you think is easier to load the dingy with, and if I use the swing ups, will the force of the wind at 28 MPH stress the dinghy?
Any advice is appreciated.
Neverhome
Neverhome
