I have seen people suggest a 40w light bulb in the engine bay to keep the chill off. I'm also familiar with automotive products such as engine pan blankets that keep the oil/block slightly warm, as well as dip stick warmers, freeze plug warmers (if you're fwc this might be an option) etc. Then there's the "marine certified" bilge heaters for a few hundred but they try to keep it around 45 degrees and are high wattage.
In addition to the usual winterization for a raw water cooled motor, has anyone tried anything else to keep an engine slightly above freezing? Are there any marine rated products that won't make me worry about my boat exploding? I can't see tossing a 40w light plub under the motor with all the fumes that come out every time I raise the lid after it's sitting.
The extra piece of mind would be nice at least, when it's 20 out in the dead of winter.
