Re: Towing a Tender Behind a Powerboat
I worked on a 54' Hatteras sportfish today and they tow a 50' Grady White center console with twin 250 Yamahas behind it at cruising speed of 24 knots (when conditions permit) when they run from the Carolina coast to the Bahamas,
The Grady has a "towing bit" bolted low on the bow, they have a bridle made that attatches to a cockpit cleat on each corner of the stern (for you not familiar with sportfishing boats, the "cockpit" is the stern area of the deck where the fighting chair is in the center) and pulls the boat from the center, about 75' back.
They motor each boat out of the marina/harbor until they are in open water without a lot of boat traffic, and the larger boat stops and drifts, the captain comes down from the flybridge while the second crew member gets the Grady close enough the line can be connected- the outboards are shut down and tilted up leaving just a bit of the skegs in the water so the towed boat will tow straight. Then the person in the Grady hops from the bow of the Grady into the cockpit of the Hatteras.
When they come into the marina they are stopping at (or fuel dock, etc.) they stop the big boat, and "reel" in the towed boat, until a crew member can hop in it, then crank up the outboards. Then the line is cast off and each boat motors in on it's own.
