I have a small problem that I need some help with. My boat is and old model polarkraft boat and the livewell is not hooked up like most I have seen. There is a 1 1/8" line that is hooked to the back of the transom down at the bottom that goes straight to the livewell on the bottom with no aerator pump between them and then there is a overflow at the top of the livewell that does hook back into that same 1 1/8 line. Then there is a 3/4" line that comes from the top of the livewell with the water spout hooked to it inside the livewell. That line goes to the back of the boat where at one point some type of pump was hooked to it. I know that aerator pumps have two points of hookup inlet and outlet so I know that one of those pumps don't go there because all I have is one hose. I thought maybe you use a bilge pump but where the hell you going to get water from. Thanks for any advise
