Re: painting vinyl seats
I have used Rust-Oleum vinyl paint on my seats.<br /> I called the co. and asked how many coats should i use. they state "2". well i used "4" coats and followed the prep directions to the letter.6 seats took 22 cans. was it worth it? yes and no. the paint can't take much bending, it will crack, and I guess, last maybe 2 seasons, if you use the boat about once or 2 times a week for 4 months. the other thing is,Rust-Oleum only comes in white, brown and black.The side cushens on my boat are red and blue, for those I used Duplicolor, which the colors are really bright, and looked great!<br />If your seats are slightly cracked, and mean SLIGHTLY! I have used liquid vinyl from dupont,that brushes on. just let it cure for a few days. the vinyl repair will turn yellow out in the sun if you don't paint over it. Hope this helps some.
